My 2009 Hyundai Santa Fe won’t start. It started losing power only to they actually. I thought it needs gas and I put gas in it wouldn’t start. Everyone keeps saying different things but I need help.
How much gas did you put in ? are you sure it was gas?
You really need to provide more information because right now there is very little to go on.
You mention losing power so did this happen on the highway? Did the engine quit running? Was the vehicle towed? Does the starter motor crank the engine over but it will not run?
The reason for my questions is trying to figure out if this is a worst case scenario in which the engine was run out of motor oil or not. Have you checked the motor oil level and if not when was the last time this was done?
When you turn the key to “start” do you still hear that rrrr rrr rrr sound?
