2009 Honda Fit - Transmission problems
2009 Honda Fit Sport not changing out of gear properly
Good to know. I will add old Hondas to my do not buy list.
Tell us more. Auto or Manual? What have you done so far? How is the transmission fluid level, and when was it last serviced (Fluid changed)?
I’m going to assume it’s an automatic. Beyond @GorehamJ 's advice I’d suggest a bad shift solenoid. I don’t know anything about your transmission but if you’re lucky the solenoid can be replaced without disassembling the whole transmission. Go to a good independent transmission shop for a diagnosis and have your checkbook handy. You’ll probably also want to think about how much you’re willing to spend on an 11 year old car.
