2009 GMC Canyon traction control fault
traction control service message fault , is on then it went off then came back on , has anyone experienced this problem and if so what was the fix for this. Thank You
Most common cause for this is the module had an interrupted signal from a wheel speed sensor. A scanner can identify which sensor. Most common causes are dirty sensor, bad sensor, bad sensor connector, damaged tone wheel that signals the sensor.
