No bus code on , engine won’t start
The car’s computers can’t talk to each other for some reason. Ask shop to
- Check battery charge
- Figure out what’s wrong with the bus system. May be some loose bus connectors. If you want to do something yourself, one of the bus connectors is usually located near the driver’s left knee, used by a shop to plug their scanner into the bus to check for diagnostic codes. See anything unusual in that area?
