clunking sounds RH side going over speed bumps, potholes, etc.
I’m guessing there’s a strut or suspension-link problem of some kind. The top strut mount areas are where I’d be looking first. Your shop should be able to ID the cause by putting the car on the lift for a look-see at the under-side.
Check for a broken strut mount as well. Really, just check everything. Suspension parts can cause very bad things if they fall off.
