2008 Subaru Outback shakes when stopped
my car recently started shaking when the engine is running but in a full brake stop or in park. what could this be connected to?
What do you mean by that?
Is the Check Engine Light lit-up?
If so, is it on steadily, or is it blinking/flashing?
Sounds like a misfire bad enough to activate the check engine light. If it’s on have the codes read and post them here. If it’s flashing have it towed to a repair shop. Tell us the codes and we may be able to help you to save $ and fix it right.
Engine miss, idle too low, vacuum leak, or any one of a dozen other causes.
Other than the CEL questions which have been asked I might ask if this came on suddenly or did it go from subtle to bad over time?
Low compression in one or more cylinders could cause what you’re experiencing as well. Very hard to tell over the interwebz.
A dirty electronic throttle body.
Have someone try cleaning it.
one of my old former Subarus developed a “slight shake” when idling, felt like car goes left/right with frequency matching engine rotation, very annoying… no codes at that time.
I tested compression and it was even between cylinders, replaced spark plugs since I was there… no dice… cleaning throttle plate did not help either…
what helped was a bottle of injector cleaner - idle became even quite fast, so I figured the trouble was the dirt on one of injectors
Does motor have vacuum assist brakes? I have no idea if Subies have power brakes.
Ever since the advent of disc brakes, I think that power assist has been a given on all makes of vehicles.
I think they have a rope with 2 cement blocks that you throw out the window to slow you down.
