I just had new pads and rotors puton and I have a constant squeaking noise coming from the front end where the parts were put. Suggestions?
Toyota uses ceramic brake pads with rubber coated shims. If you had some place else install aftermarket pads, they will squeak and or grind. Either use Toyota pads or I us Akebono Ceramic pads. I bought the Akebono pads for my 09 Camry SE at www.Rockauto.com but for my other Toyotas I use Toyota pads.
