I would like to know the part number or web site I can buy a heat shield for a 2008 Lexus ES 350. The one the car came with disintegrated.
Thanks.
If this is part of your exhaust any muffler shop can fix this easier and maybe even cheaper that you can .
I use RockAuto.com. Factory parts can come from https://www.mylparts.com/ and other sites.
Or visit your Lexus dealer and let the parts counter folks help you find the part you need.
Your car probably has several heat shields, so nobody is going to be able to give you a part number based on the information you’ve posted.
Some heat shields are a part of an exhaust component.
So, you can’t just replace just the heat shield. But the entire component has to be replaced.
