2008 Jeep Compass - No running lights
brake lights,turn signals good…no running lights…fuses in main box under hood all good
With a voltmeter and running lights on, check power and ground. If you have 12 volts and good ground, replace bulbs. If not find bad wiring between bulb and switch. Or bad switch.
