My Honda CR-V VSA Check engine light are on putting out code P2646 iv cleaned the screens but problem still persists please help
Read the “Tech notes” here:
As a fyi for the OP, it is critical to observe the manufacturer’s recommendations for oil change intervals and oil specifications with engines using variable valve timing. Prior to VVT there was some flexibility, but not with VVT.
