Hi there,
I need help with a liquid leak issue. My car has been leaking clear liquid from a small open tube behind the engine. I’m not sure what it is but it has been causing my vehicle to sound louder than normal. Any help and tips will be great appreciated
Clear is the clue here. I think it is the A/C drain. But that is normal and would not make the the car any louder than usual.
Check the exhaust flange donut gasket. They usually go bad with age and start to make noise.Plug the tailpipe with a rag and listen for the noise
