Car overheats while stopped. drivers floorboard is wet. Replaced all hoses and thermostat. Visibly leaking from front of engine compartment on drivers side.
It sounds like you still have at least two coolant leaks, one for the heater core and another under the hood. I would check the freeze plugs under the intake manifold.
Leaking what? Water? Coolant (smells a little sweet, feels a bit oil)? Oil (smells and feels oily)?
Does it still overheat when stopped? Are your engine cooling fans running when the engine is hot?
