2007 Toyota RAV4 power steering goes out
If the battery/charging system voltage drops to a critical level the power steering will shut down but at that point the battery is usually too weak to restart the engine.
With the intermittent charging system warning light I suspect there might be a loose battery cable connection at the battery or power distribution center.
Auto Zone won’t be able to access the fault codes in the steering control module, a professional scan tool is required.
