Grinding, repetitive sound from the right front when turning left.
It’s hard to say without hearing it when it occurs. the noise could be from the suspension or wheel bearing, or even the brakes. Take it to a competent mechanic, tell him what it does, then let him diagnose it. If you don’t understand what he says, ask enough questions to get comfortable with the explanation. The shop should be happy to explain it to you. If it helps, you can let us know what they find and we can help you understand it.
Look under the wheel area for a broken plastic wheel-well or under-carriage shield. It might have come loose and is rubbing against the wheel during turns.
