After getting a routine oil change and filter change the cruise control light failed to come on driving home from the workshop.
Does the cruise control work with the light off?
Is the check-engine light on?
Check the engine oil level. And the transmission fluid level. With alacrity.
The cruise control doesn’t work with light off.
from what I recall off my 2006 Pathfinder, cruise control is forced off by ECU until VDC calibrates itself
do you have “VDC off” light illuminated by any chance?
