2007 Lexus RX 350 - Dash crack
my 2007 lexus dash board is cracking.
Found this…
  • DO YOU HAVE A CRACKED LEXUS DASHBOARD?
If you’re a Lexus owner, you may have noticed that your dashboard has started to crack. This is a common issue with Lexus vehicles, and it’s one that can be frustrating to deal with. In this article, we’ll explore how a cracked Lexus dashboard occurs, what you can do to prevent it, and how you can fix it if it’s already happened.
Why Do Lexus Dashboards Crack?
There are a few reasons why Lexus dashboards crack. One of the most common causes is exposure to sunlight. Over time, the sun’s UV rays can break down the materials used to make the dashboard, causing it to crack. This is especially true for cars that are parked outside for extended periods of time.
Another cause of cracked Lexus dashboards is the use of certain cleaning products. Some chemicals can be harsh on the dashboard’s material, causing it to become brittle and crack. It’s important to use cleaning products that are specifically designed for use on car interiors.
Do You Have A Cracked Lexus Dashboard?.
They make a dashboard overlay. Secured with silicone adhesive - no drilling or cutting required more details on - Coverlay® - Lexus RX 2007 Dash Cover
After only 16 years? You should sue Lexus!
Please be sure to keep us updated on the progress of your litigation.
:smirk:
There was a warranty extension for the instrument panel safety pad that expired in 2017. Dash pads shouldn’t crack and peel like these do, you wouldn’t want dash pad pieces in your eyes after the passenger airbag deployed.
