Clunking front end Had new rack installed Did not help,New Struts,did not help.Clunking every little bump.Driving me NUTS.
Since you’ve replaced the struts and rack, ask your shop if it could be tie rods or control arm bushings or ball joints. And areyou sure it is coming from the front suspension/steering system? Stabilizer links too.
It could be something in the trunk that’s moving around and banging into the side of a fender or a loose jack component etc.
When does the clunking happen? It could be bad CV joints.
