I have two issues with my 2007 Fusion. First: I cannot open the driver side door from the inside. Second: recently I am not able to remove my key from the ignition after putting it in park and turning off the engine. I turn the key to the lock position which is where it needs to be to take out the key. Is this a switch problem or a transmission problem? I have done two things to be able to remove the key. Move the shifter back and forth several times and disconnected the battery.
Related topics
| 05 Ford Focus | 3 | 415 | June 24, 2007 | |
| Car Key Stuck in Ignition | 3 | 753 | October 7, 2009 | |
| Fors Taurus won't start | 2 | 543 | September 9, 2009 | |
| Car will not turn off | 5 | 675 | September 12, 2009 | |
| Cannot remove key when car in park | 1 | 374 | May 3, 2008 |
