How do you reset the service engine light on the '06 Scion XB after doing an oil change and lube?
I guarantee that it’s in your owner’s manual. So is lots of other really important stuff.
But, I copied this off another forum…it should work: http://townhall-talk.edmunds.com/direct/view/.efc5081/96
- Step 1 - Turn the key to the ‘on’ position. Using the trip meter button, toggle the LCD display until ‘ODO’ is displayed.
- Step 2 - Turn the key off. Now, push and hold the trip meter button. While holding the trip meter button, turn the key to ‘on’.
- Step 3 - While you continue to hold the trip meter button, you will see on the LCD display 5 small dashes and they will begin to ‘count down’ rather quickly.
*Step 4 - Continue holding the trip meter button and once all the dashes have been cleared, the LCD will display six zeros (000000) - release the trip meter button now - and then the LCD will display ‘ODO’ and your current mileage. At this time, your ?Maintenance Required? light has been reset.
