2006 Ford F250 - Steering Locks Up During Turns
Often now, when making a right turn the steering seems to lock up momentarily but then works again. What is the cause?
Bad steering rack-suspension links binding - or could be something else . If you are not a mechanic that can do front end work then put this in a shop before it really fails and you crash and injure yourself and someone else.
