Ford 2006 f250xlt2006 runs well for about30minutesTan true to stall drive another 20-30minutes and truck stall and won’t restart
A common problem with ford trucks around your year is a faulty gas fuel pump driver module.
Ford F-250 gas fuel pump driver module - YouTube
but other things can cause your problem. just to give a few.
A faulty fuel pump or fuel pump relay heating up and shutting off. when it cools it will work again.
a dirty fuel filter will cut fuel off. after it sits for a little while some of the dirt will fall off filter and will let you start the truck again for a little while until it clogs again.
do you have a check engine light on? if so, post the codes here and maybe someone here can help you more. most Autoparts stores will scan your truck for free.
OP, for best help here, suggest to edit your top post so it is easier to understand.
