I own a 2006 Ford Escape V6
I noticed I have a tiny oil leak now, after I drive it. I only have 62,000 on it. I put leak stop in and it seemed to work for a while, but now its back, Ugh.
/should i put money into the repair (since the car is now 13 yrs old?) I’m afraid it will be costly, but otherwise the car is fine.
If you can identify where the leak is coming from it will be easier to answer
If you can identify how much oil is being lost it would also be easier to answer.
