2005 Ford Taurus - Seatbelt issue
Drivers seatbelt won’t click to lock.
Look down in it for any debris that may not allow full engagement… Have you tried the passenger side to see if it will click in the drivers side??
Spray some silicone lube into it and it should free everything up inside and make it so it will latch again.
Thoroughly clean it first then spray with silicone. If that doesn’t work, replace it.
