2005 Chrysler Pacifica - Crank sensors
05 Pacific@ was driving 65 mph car completely shut down said cam or crank change both sensors still cranks no start still says cam bank 1 sensor 1
3.5 L engine? Check if the timing belt failed.
That should throw codes for both cam sensors.
There is only one camshaft position sensor, it is on the left bank.
Oops! Just checked my FSM. You are absolutely correct, as usual.
