I have a 2005 Chrysler 300 ltd and have a leak moonroof. The leak is in the rear back corner of the moonroof assembly. The drain tube has been blown through and cleaned and there is water coming out of the wheel well, but there is also water pouring out of the moonroof rail only on that corner. Is there any known fix I can try other than permanently sealing off the moonroof?
Replace the seal that is leaking. It didn’t leak when it was new, so re-new the seal.
I think the seal is within the housing of the moonroof since the water isn’t coming from the edges. How do I get in there to get to that seal?
This is where Google is your friend . Just put in ( replace sunroof seal 2005 Chrysler 300 ) . That should find you videos and let you decide if you want to try or have a body shop do it.
