Just had BOTH front wheel hubs/bearings replaced with Moogs. I now have a SNAP sound coming from the front by the brake area when i put it in gear and torque the brakes in reverse/drive OR in gear and hit the gas quickly i hear it…New brakes all around too,not the issue.Could the front axles be damaged from removal? 64 k on it, runs ultra smooth. Thought about selling it for $2500 due to a great motor,has front lower fender rust holes from a poor design that traps water/snow/junk.Newer struts.
Unlikely but not impossible. I’d get this thing checked ASAP at the shop that did the work just to make sure everything is actually tight. Especially the axle nut that goes thru the new hub assembly.
