2004 Toyota Solara - Cracked dash
middle section is cracking now. this is after the dash fix. one problem to another. pressure points in the dash
do you have a question or just venting? you had it replaced once on the extended warranty. your car is too old for them to do it again. you can by a dash cover and motor on.
2004 Toyota Solara Dash Cover - Front - from $29.99+ | AutoZone.com
