2004 Pacifica ELECTRIC
My MPH gauge, odometer, transmission drive indicator does not work on the instrument panel. The RPM, all other gauges and lights work. My car also doesnot shift out of 1st gear.
I suspect that the Vehicle Speed Sensor (VSS) is defective.
It sounds like you have a power problem to the areas mentioned. Have you checked the fuses to see if they are good? If not, I suggest you do that first. If they are ok then I would verify that power is getting to those areas.
