2004 Ford Crown Victoria - Heat will not stop
I installed new heat control module but heat still comes thru either the vents or the defrost or the floor and does’t stop even though the temp. is set at 60 degrees. The fan control works fine.
if you just changed the control panel that controls your heat and a/c that was probably not your problem. there is a air blend actuator by heater door that goes bad that you need to change. it goes bad on alot of fords.you can look on you tube and see how its replaced.
