Hi,
My 2004 Corolla CE has 62K now and I’m considering getting the 60K maintenance done soon, especially since I skipped the 30K maintenance. Below is the list from the maintenance guide. The car has never been used for towing or driven on dirt roads, therefore I skipped the “special driving condition” part of the list.
- Replace engine oil and oil filter
- Rotate tires
- Replace cabin air filter (if equipped)
- Replace engine air filter
- Inspect the following:
__ Ball joints and dust covers
__ Brake lines and hoses
__ Brake linings/drums and brake pads/discs
__ Differential oil
__ Drive belts
__ Drive shaft boots
__ Engine coolant
__ Engine valve clearance
__ Exhaust pipes and mountings
__ Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
__ Fuel tank cap gasket
__ Radiator core and condenser
__ Steering gear box
__ Steering linkage and boots
__ Transmission fluid or oil
I don’t want to pay dealer’s high price because:
a. This car comes with timing chain instead of belt (therefore no need to change the belt)
b. America Tires have been doing #2 below for me regularly (since I replaced all 4 tires there)
c. I guess #3 (cabin air filter) and #4 (engine air filter) should be relatively easy to replace, and I can purchase these filters from some auto parts store.
d. #1 (oil change) can be done at ~$30.
e. That leaves #5 (inspections) to be done, which I guess should be inexpensive.
Is my understanding correct? Do you think oil change/repair centers (like Jeffy Lube, sears, Midas, etc.) will accept an inspection job like this? Could someone recommend some places that do good inspections? Your help will be greatly appreciated.
Thanks!
