Have above with 179k miles, and jsut did replace the intake gasket set, the crank sensor, and the fuel pump in tank. Started and ran rough prior to fuel pump R & R, but now only turns over and not starting. Tach is not moving either. Help!
The ignition system may have a problem or it could be the fuel system. I suggest you first try spraying some starter fluid into the intake to see if that gets it fired up. If it does, the fuel system needs to be checked for a problem. If that doesn’t work then check to see if spark is getting to the plugs.
