I have a 2003 echo. I was sitting at lights with clutch in and when light turned I let out clutch and started to move then there was a noise like the transmission jumped out of gear and then car wouldn’t move, just revved like in neutral, didn’t matter what gear you put it in. What could this be? Any help is appreciated
Broken transmission, broken cv joint or axle, stripped drive hub, blown clutch. Could be any of those.
