Ihave a 2003 Toyota echo , automatic with 175,000 miles It started a few days ago : my oil light and check engine light are on as soon as I open the car door before the key is put in the ignition When I try to start it it doesn’t turn over and I can’t even get it out of park as the brake switch doesn’t work either ! Damdest thing I ever seen . Anybody got any ideas /
Could be a bad ignition switch internally stuck in the run position.
Related topics
| 2000 Echo shuts down intermittantly | 7 | 2193 | May 1, 2021 | |
| 03 Toyota Echo | 1 | 413 | December 1, 2009 | |
| 2001 toyota echo | 5 | 1689 | October 6, 2010 | |
| 2000 Toyota Echo, engine and brakes | 3 | 822 | October 5, 2009 | |
| 2000 Toyota ECHO ignition switch | 1 | 529 | January 30, 2019 |
