Car seems to be working fine, but making noise. It’s been suggested it’s the muffler. If it is, I’m wondering what the cost should be.
I’d guess maybe $400-$500 for the replacement part, and 3/4 hour labor. Muffler replacement isn’t a technically complex job, most shops are qualified to do it, suggest to shop this job around among your local well-recommended independent shops for some price quotes. You could use a short length of garden hose as a stethoscope to better narrow down where the noise is coming from.
I would suggest someone stole your catalytic convertor. If that is the case and you live in California, get ready for a larger bill than $400-$500.
Here’s to hoping the OP’s problem is the muffler and not a missing cat.
Have the exhaust system inspected,
If it’s a bad muffler, missing cat, or failed flex pipe,
will determine the cost.
