2003 GMC Yukon - Low Power Mode, Service 4ws, Service Brake
lo power mode dtc code p1518 service 4wd servicebrake system all show up on any bump
3 distinctly different problems needing repair…
Bad throttle body actuator, likely a bad 4WD switch and low brake fluid, maybe.
Since all of these warnings appear whenever you hit a bump, I wonder if a connection in the wiring harness could be loose? Just a thought…
