when hand brake is on and you get in or out
there is a noise coming from the back wheels. it jus moans and groans and you
can hear it all over the parking lot.
Does this sound occur when the vehicle is moving, parked, or both? Your post is less than specific.
this noise comes when you are getting into the car
before you even crank it up. it will make this noise
even without the hand brake being set.
Check your trunk. Did you unknowingly run over someone when you parked?
Check the parking brake engagement system under the car. It sounds like when the body moves relative to the wheels some part of the system is being put under strain and/or rubbing on something.
