2003 Caravan, No Crank No Start, help please
The Van is a SE 3.3l v6 flex 140k. I’m having a problem with no cranking. It does not have an alarm or a chip key system. I ran out of fuel the gauge showed 1/4 full. I had the fuel pump and filter replaced. The van started and ran great. I returned later the Van would not crank. Replaced battery, no crank, used a remote starter it will crank with key on it will not start. Had ignition switch replaced. Van started and ran. Went back later no crank no start. Put on a noid light to #6 and it flashed correctly. I took it off and reattach connector. I turned the key and it started and ran smooth like it has been. Went back later a no crank no start. Thank you for a reply.
I hooked a led test light wire to battery ground and the probe to #86 of starter relay terminal. Turn the key to engage the starter and the probe lights up. Thank you for a reply.
First confirm battery is fully charged. Second clean both sides both ends of battery cables. Then check both sides of relay. If that doesn’t do it post back.
Both ends of cables are clean. There is no voltage drop on the cables. The battery is very strong, 12.6 v less than a year old.
Check both sides of relay? I sorry I’m green on this. Please explain, thank you.
