My 2003 Audi A4 turbo manual ABS warning light comes on intermittently and often. The traction stability light comes on at the same time since it is dependent upon the ABS. It happens sometimes at startup and will go off if I turn the ignition off and then back on. It also comes on sometimes when I am stopped at a light after driving. The speedometer doesn’t work when the warning lights are on. I have felt the ABS activate a few times when not needed. Is this a computer issue or is there a deeper issue with the ABS?
Related topics
| ABS brakes activate momentarily all by themselves? | 12 | 1261 | November 2, 2010 | |
| 2003 Toyota 4Runner - intermittent warning lights, speedometer stops | 1 | 534 | January 3, 2019 | |
| 2003 Honda Accord Coupe V6 | 2 | 873 | November 5, 2014 | |
| 2004 Chevy Monte Carlo SS | 1 | 335 | August 22, 2008 | |
| ABS Warning Light Malfunction | 2 | 721 | April 24, 2011 |
