Red temperature light every time and all the water in radiator dissapear and dry
Two choices, well. actually three.
- Have repaired.
- Junk or sell for parts.
- Drive as is then replace engine when it self destructs. You might have reached that point already.
You’ve got a extremely massive coolant leak
To be brutally honest, it should be super obvious to determine where it went
Put the car on jack stands and get under there on a creeper
See any obvious dried coolant residue . . . there should be a LOT
If you can’t see anything, get a garden hose and remove the coolant pressure cap. Slowly start putting water into the cooling system. My guess is that you will very quickly see a geyser . . . could be from the water pump, block, radiator or something else
It’s possible you’ve already seriously damaged the engine by apparently repeatedly driving the vehicle in this condition
