2005 Toyota Camry - water drying up from radiator
Water drying up from radiator
I think you have a leak. Internal or external? That is the question.
Water drying up from radiator? I have no idea what you are asking, You have coolant in your radiator and it does not dry up very easily.
Do you mean the coolant level is dropping in your radiator or reserve tank? Is water on the outside of your radiator?
The very way you frame your non-question makes me think you should see a mechanic.
Five words (which don’t actually explain the problem) are not sufficient for any of us to give advice.
Perhaps the OP can expand his description of the problem so that we have a better idea of what is taking place with his car.
