Front head light failure. I’ve replaced the bulb with no resolution.
did you check the fuse?
The OP should be glad that this didn’t affect his rear headlights!
- Replacement bulb is faulty
- Electrical power not getting to bulb socket
- Fixture ground has come loose
- Bulb socket damaged or corroded
- Computer module faulty
Ask you shop to test for each of those, one by one. Eventually they’ll discover the problem.
I suspect the ballast has failed.
