I have air coil springs and I can’t find any to replace the one I have on the right front. Can we convert both front springs to regular without air and leave the back ones air? How would you cut off the compressor?
A Google search turned up a place called Strutmasters ( not a plug or endorsement ) and there are sure to be others that have kits to do away with the air suspension. Call around where you live and you should find a place to do that for you. Have them provide the kit as that will give you better warranty coverage. I would do the whole thing - front and back .
