Hello:
I have a 2002 Durango 2WD about 115000 miles. I have steering noise and some play. I can hear the noise when the truck is park and move the wheel from side to side about an inch. I had the upper ball joints replace, outer tie-rods and wheel bearings some time ago. Could this be the gear box. I now this trucks are notorius for ball joint problems if it says Durango in the back yeah your ball joins are bad. At the moment I am parking the truck and have it check over the weekend.
Thanks for any advice.
