i have one that is slipping in over drive and drive what do i do to fix the thing
I assume you mean the transmission. Try dropping the transmission pan and taking a look inside. If it doesn’t look too bad, you might get away with a fluid and filter change. If there lots of trash in the pan, you are in for a rebuild.
