2001 Volvo XC70 - engine seal blowout
2001 V0lvo xc v70: symptoms of an engine seal blowout?
Which seal? Front/rear main, cam, valve cover, oil filter, front trans? Biggest symptom is ……… oil leaking.
Oil leaks. Coolant leaks. Either type could be an internal or external leak. If you seem to have a lot of engine seals failing, a problem w/ the pcv system is a likely culprit.
