I have a Nissan truck with about 108,000 miles, automatic transmission, with a four cylinder engine. I feel a pretty good bump in the rear when the gears shift, usually only in shifting from 1st to 2nd or at low speeds. It feels like something is giving way under the torque of the shifting motion. I have replaced the rear shocks and inspected the u-bolts holding the leaf springs to the rear axle. There seems to be excessive movement at the juncture (u-joints) where the drive shaft meets the rear end gear housing. The whole rear axle assembly seems to be rocking back and forth. I can see this when I rock the truck back and forth by pushing on the rear tires. I would love any advice as to what might be the problem here.
Related topics
| Knock / thump from rear at highway speeds | 3 | 525 | December 22, 2013 | |
| 1997 Ford Ranger, 198K, noise in the rear and slipping | 2 | 852 | February 22, 2009 | |
| Chev 2003 silverado shudder from rear transmission | 7 | 945 | March 23, 2010 | |
| Clunking / rattling sound in manual transmission | 5 | 8236 | February 1, 2014 | |
| 1995 ford explorer vibrtion/shaking | 4 | 1921 | September 8, 2012 |
