I have a 2001 Daewoo Leganza that I haven’t driven for about ten months. The car was parked in my driveway during the heavy winter snowstorm. One day, when I was inspecting my car, I found out that the front driver side floorboard was wet, and my coolant reservoir was completely empty. I also think my power steering fluid level was a bit lower than the MIN line. When I peeled the floorboard, the liquid from the floorboard had some hint of a green color, and smelled funny, so I think it was coolant plus the rainwater.
The front right tire keeps losing air, and there is vinyl wrinkle damage near the power window controls on all four doors. I suspect this came from water leaking into my car from the windows. My battery was also completely drained.
So far, I’ve only gotten the battery replaced and I refilled the coolant reservoir with 50,50 mix. I’m not sure if it was the same type or brand of coolant that was used before. When I installed the battery, I checked my power windows, and my rear right window fell and couldn’t get back up. The motor made noises for a bit, but now it has completely stopped. I took off the door panel and could only get a glimpse of the motor. It looked like the wires were frayed but I didn’t really know how to take out the entire unit.
I’m planning on siphoning the gas from my tank into gas cans and refilling her up with fuel injector cleaner and fresh gas, and then change the oil and filter to see if the car will start. If it starts, I was going to try to locate the AC drain and try to unclog that, but I’m not really sure how to use the floor jack to jack up the car properly. My car is currently resting on a incline with the front of the car lower then the rear of the car. Can I do this on a slight incline surface?
Note: A year ago, I had coolant leaking at the sides of my car and a heater bypass was done on my vehicle. I think I hit something on the road, and it ruptured something. My vehicle overheated, and the radiator, thermostat, new hoses were all installed.
These are the tools I have with me, a multi-meter, two 5 gallon gas cans, wrenches, sockets, a bluetooth OBD II reader with the free version Torque, door panel removers, jack stands, lift, 2 wheel chocks, and a creeper.
What are the precautionary steps that I have to take to get the car running like normal again? I’m worried if I start it, it might break in the process.
