Car over heats ONLY after driving for awhile then idling for more than 5 minutes
Do you have a question?
There is a long list of things that could be the problem. If you aren’t going to fix it yourself, take it to a service shop. If you are going to fix it yourself, post back with more info and we will try and help.
Check your coolant level, and make sure both fans come on when they are supposed to.
