the turn sigals on this car got me some what baffeled it seems that when you turn them on the left front and right dont blink inside the car on the display the left side blinks fast an on the rightside it doesent flash at all but you can hear it flashing fast an also rear blinkers both left and right blink fast when turned on.and the forways seem to work fine on all four lights,just hope i dont have to do what i think,an that would be to replaced the whole indicator switch on the steering colum…
Since the 4-way flashers are working ok I would start by first replacing the turn signal flasher unit and see if that clears the trouble. If that doesn’t work then I would check to see if the turn signals run through the flasher circuit switch. There may be a problem there.
thank you i,ll check it out…
