2000 Toyota Tundra - Recall
Is there a recall for severe frame rust on 2000 Toyota Trunda? My frame have rusted through on the right front.
No one here can answer that with complete certainly. Go to www.nhtsa.gov and have your VIN handy and you will find out if you are covered . Or you could call your local dealer.
Toyota safety recall BXD for 2000-2003 Toyota Tundra trucks originally sold or located in cold weather climate states involves frame replacement if corrosion perforation in one of the rear cross members is found.
This is an old recall, if this recall has already been performed on your truck a corrosion resistant compound should have been applied to the rear section of the frame. Visit a Toyota dealer for inspection.
